Hook up remote starter switch?
enginesilo
I'm having some engine issues and figured it may be easier to hook up a remote starter switch so I can attempt starting the boat from the back. Any tips on exactly where the clips on the remote starter go on a Volvo 5.0 GXI-B (Fuel Injected) engine? Looks like there are 2 leads that need to be hooked up. Does one go on the positive battery lead, and another on the starter, or a solenoid of some sort somewhere?
Thanks for the help.
Connect remote start on the large starter post and the other on the Yellow/Red on the smaller post. Turn key to ON then go to the motor and start it
VP Starting.jpg ​​​​​​​
enginesilo
Thanks for the tips. So in that diagram is it screw C, and screw D? Are there 2 large posts? Is that the starter solenoid they are hooking to?
