horn and trim
cooter2506
Hello been a while. I changed the battery in my boat since it was dead and wouldn't charge. Changed battery and got all lights, gauges and depth finder to work. Now the bad. I have no trim at all not even a click and the horn just clicks doesn't blow(didn't know how else to put it). Got dark so I didn't even start to investigate yet but thought I could get some ideas before the morning. Thanks
Re: horn and trim
Ayuh,.... Did ya hook up the wires at the battery, for the Trim Pump,..??
bonzoscott
Re: horn and trim
Also, them connections at the battery need to be clean and tight. It may look clean but always at beginning of season, sand paper connections and if the battery has wing nuts use pliers. Ive seen the negative cable nut turn color from heat and poor connection.
