Horsepower rating
thunder219
I can not find the ratings for my eng. I was told that it is 160hp. It is a 1994 G W Invader and thinking about putting on a different prop for pulling the tube because the one thats on it is a 21p and thinking about trying a 19p high five.
Eng. OF-267475
Transom num. OF-329447.
Stern drive num. OF-245522
Also if someone knows can you tell me where I can find these things on the net. Thanks for any info.
Re: Horsepower rating
There's a Prop Forum further down the Main Forums Page,....
That's Where this Question should be Posted.....
And,.... When you get there,....
Everybody is going to Need to know your RPMs at WOT.........
That's the Most Important #s there are to Spec.ing a Prop........
thunder219
Sorry, I wasnt really asking about the prop rather than the hp rating. I just put the part about the prop in there because I think a high five would be too much prop for 160 hp. Everything I have read, the 4.3 around that year their ratings where all around 175. I was just wandering if it is 160 what the diff. is between what I have and all the other ones. I know some have 4 barrels and they have higher rating. Sorry for the confusion, kids been eating easter candy all day and its hard to concentrate. Thanks
superpop
with the 4.3L GM Blocks the things that make a big difference in HP are the Carb and Heads. Vortec heads add some HP as does a gas dumping 4 barrel like I have. I just put a 14.5 X 18P Stainless 4 blade on my 1996 4.3L Vortec motor and I expect that it will be perfect for hole shot. Had a 21P Stainless and a 19P alum both 3 blades and neither had any hole shot. Course this was on a 20 foot boat. You need to figure out Max RPM's before you do anything else.
