since Ive been having lidle problems, how do I bypass the safety switch and crank the motor in gear?
J jus4funn2010 Seaman Apprentice Joined Aug 30, 2010 Messages 49 Jun 21, 2012 #1 since Ive been having lidle problems, how do I bypass the safety switch and crank the motor in gear?
H Haffiman Commander Joined Dec 17, 2009 Messages 2,454 Jun 21, 2012 #2 Re: how can I crank my 225 johnson IN gear You will have to buy-pass it in the remote. (connect the two red/yellow leads going into the switch)
J jus4funn2010 Seaman Apprentice Joined Aug 30, 2010 Messages 49 Jun 21, 2012 #3 Re: how can I crank my 225 johnson IN gear thanks LC that is what I needed. Ill only use this if I just have to.
Scott Danforth Grumpy Vintage Moderator still playing with boats Staff member Joined Jul 23, 2011 Messages 52,521 Jun 21, 2012 #4 Re: how can I crank my 225 johnson IN gear why not fix the idle problems, starting in gear can be dangerous, especially if the throttle is cracked
stylesabu Master Chief Petty Officer Joined Aug 2, 2009 Messages 849 Jun 21, 2012 #5 Re: how can I crank my 225 johnson IN gear its also bad for starter and battery,they both have to work harder.I agree with scott fix idle. on the water is no place to be adjusting/fixing boat make sure its running right everytime before u leave the dock.
EricJRW Chief Petty Officer Joined Feb 3, 2010 Messages 488 Jun 21, 2012 #6 Re: how can I crank my 225 johnson IN gear My remote has a button to advance the throttle without engaging the gears. Is this not standard?
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Jun 21, 2012 #7 Re: how can I crank my 225 johnson IN gear Why would you want to crank the mtr in gear ??
