How can I find small leaks?
Re: How can I find small leaks?
Then be proactive
Buy a can of gluvit and do the rivets and the seams ...... it will prevent any future ones
5150abf
Does it leak when you are using it?
Usually water leaks in and not out...... been there done that......
5150abf
It is probably a rivet on the keel, mine did that, it would drip in the garage for a coulpe days after you used it.
Mine turned out to be that I actually wore through the keel from years of beaching, a little weld and a keel doubler and it is dry again.
Rebuck if you can or use Gluvit on it but you have to be able to get to the bottom of the boat either way or you could always just let it go if it is a small leak, sometimes the cure is worse than the disease.
