How can I tell if my engine is making the amount of power it should?
Reel Poor
Re: How can I tell if my engine is making the amount of power it should?
I'm not sure, maybe someone else will chime in on this but I think WOT on the 2.3 liter is around 5000/5200.
kwikrnu
boat
Starflight
my 17 footer w/ just me and a 1/2 tank of gas will reach 37-38 (gps) w/ 130hp and a 14x19 prop @ 4900-5000 rpm
when i have 6 adults on board i have to use a 14x17 which gets 25-27 mph and will only run 4300-4400 rpm.
when i'm alone w/ the 14x17 it'll go 33-34 @ 5200
btw....black smoke usually = running rich. whens the last time its been tuned up?
That is with 6 people on the boat.
In a 17' Boat,..??.......
Loose some of the Tonnage,+ it'll probably run Much Better.........
whywhyzed
Banned
with a small boat with small power, you usually need at least 2 props. 1 for the family outing and another for flying solo. Check the pitch of the current prop and get another that is 2" less pitch. e.g. if current prop is 19P, get a 17P for heavy load boating
kwikrnu
boat
kwikrnu
boat
kwikrnu
boat
Starflight
usually they are stamped on the backside of the prop. my boat has the same load rating, and if i were to have to run w/ a full load often, i'd get a 14x15. at full load my boat struggles to get on plane even w/the 17" pitch. my usual load includes me, wife, 6 yr old son, and a jack russell, and the 19 pops us on plane quickly.
the diameter is not going to change the performance as much as the pitch will.
how does your boat perform w/ just you in it? you need to check and see if your tach accurate before swapping props, and make sure the engine is tuned properly.
Starflight
a tune up should include...plugs, cap & rotor, points. dwell checked and adjusted. then timing set at idle (w/shop tach or timing light w/ built in tach) and checked for proper advance. compression check and carb cleaned and adjusted.
kwikrnu
boat
Starflight
w/o tearing the floor out, you cant tell if its water logged. our local land fill lets us check weight on thier scale for free.
the picture may be deceiving, but the pitch looks to be more the 13"s
good luck bro.
kwikrnu
boat
Starflight
dude, i believe you have performance issues. ie poor compression and or tuning issues. your engine should spin that prop up to wot w/ a full load no problem. it wont push ya fast but it should spin easily. have you confirmed your tach to be accurate? the speed your getting w/ it and 6 ppl doesnt seem too far off from what i would estimate it would be.
kwikrnu
boat
4winnsskipper
I just purchased a 1989 runabout type ski boat 17' fiberglass boat. It has a small 2.3 omc. It runs okay but at wot which is around 4200 rpm, it only goes 25-27 mph. Should it go faster? That is with 6 people on the boat.
maybe its just me but with a tiny 2.3L, 6 People, running 25mph seems good to me. loose 4 of those a-holes and you'd pick up to around 35mph i'd bet, which i think is also right on. :p
sabastianunf
I would say you are right on track with the comperession test befroe buying any new parts. I am not positive but a bad ring could be causing the black smoke - a compression test will tell you more. You can buy most parts for a tune-up off this website but I would try to find a local repair shop and they will definately get you the correct parts and maybe some good advice once you get to know them. I would try to find the manufacturer recomended rpm range at WOT. A motor that small and old may be doing all that it can. Also could you post a pic of the engine cover/ back interior of you boat - just interested in how it is set up. thanks.
kwikrnu
boat
kwikrnu
boat
