How Clean...
HollaGeo
My father just sold his house and gave me his stainless steel bbq (Char-Broil). It's ten or so years old but in relatively good shape. I cleaned the whole thing today with soap/water and a high pressue hose. A bunch of that grease came off. But a considerable amount still remains on the metal grill things and everywhere below. Basically, how much of that stuff has to come off for it to pass as "clean"??? Also, the ignition switch is broken, which needs to be replaced. I personally have no idea how to do this and am thinking about calling a repair tech. to come and basically do a tune-up. I am assuming that bill would be somewhere in the $200.00 range. With that said, is it even worth trying to restore this thing??? From my limited experience in bbqs, I would say this bbq was a high end unit back in its day...
NYBo
Re: How Clean...
Try oven cleaner on the grease.
There are universal igniter kits that are pretty simple to install. Here is one example.
Re: How Clean...
I have a VT Castings SS grill and I use ZEP degreaser from Home Depot and a green scrubbie ......it kicks the grease in the butt and does a great job cleaning. I follow that with some spray SS polish and it always looks brand new.
Yup the ignitor is usually the first thing to go and a PITA but just replace it with one available from most stores.
superbenk
Re: How Clean...
Start the grill up and let it get really hot - it'll burn off most of that grease & you can just use a wire brush to get the ash off.
ezmobee
Re: How Clean...
This is a Char-Broil, not a Weber. I think $400 gets you like the top of the line model new. I don't think there is any such thing as a "high end" Char-Broil. Do not call in a pro to work on this thing.
That being said, I'm not sure how Char-Broil is but even my cheap Brinkmann has been easy to get parts for so if you can get a model number off the thing you should probably be able to order anything you'd need. If it's in good structural shape it would probably be worthwhile for you to get it going again.
greenbush future
Re: How Clean...
Most certainly do not call a grill tech, and be careful about ordering parts, most OEM grill parts are way, way overpriced. Ducane was asking $80.00 or so for the rack that held the briquettes. I found an $8 rack at K-mart.
If you really want to clean it, fire it up with a sheet of tin foil on the grill surface (completely cover the cooking area) and run it for 30 minutes on full heat-lid closed. You will have nothing but crispy ashes to scrape off with you grill brush. I do this after each use and it never gets real bad.
lncoop
Re: How Clean...
Speaking of parts, how are the burners? If they're shot it will likely cost you quite a bit to replace them. You might get lucky since it's a common brand, but in my experience burner replacement out of warranty ain't cheap.
