How do replace a 1990 Trophey 150 Force to a Johnon 150 - Brackets dont match !
oldtacklebox
I would like to replace my 1990 Trophy Bayliner 150PH Force with a 1983 Johnson 150. After I removed my Force motor I found that the bracket mount and boat holes are different and the Johnson motor mount bracket was a lot smaller then the Bayliner :facepalm: The bracket doesnt fit completely onto the transom wall :(. The bayliner wall is thicker and the bolt holes are straight and spaced apart. I need to know how to make this transition :confused:.
I need to get the transom bracket to fit right. Please help!
If anyone out there knows how to make this transition please send me photo's and instructional help .
