How do you apply registration number and sticker...
chickendog2010
..on your inflatable? I am looking for a few alternatives and advices before doing it. :)
Sea Rider
Re: How do you apply registration number and sticker...
Will need pvc 2 part glue if it's a pvc sib, hypalon glue if it's a hypalon sib.
Happy Boating
dwco5051
Here's another option directly from Pennsylvania display regulations;
(3) Inflatable boats and boats configured in a manner that a number on the hull or superstructure would not be easily visible, and unless special provision is made by the manufacturer for display of numbers, may carry registration numbers and validation decals on boards to be lashed to the bow on each side of the boat.
TOHATSU GURU
Virtually everyone uses three inch stencils and fills them in with a permanent black marker. You end up doing it about every 6 months or so. Or, you can buy an inflatable registration kit for $40.00, which comes with 3" stencils and black rubber paint....That you will need to re-paint every 6 months.
Whoopbass
This is how my CF #'s are displayed. The board is PVC so the numbers will stick.
I heard it wasn't legal here in CA so you might want to check first so your in compliance with your state laws.
chickendog2010
Hum...i am thinking of using a permanent marker for registration number and velco for the sticker :D
FH alumni
I went with the plate made by boatnumberplate.com. It glues to the side of your boat and has a 10 yr guarantee. Looks nice and was ~ $40. The numbers are etched or melted into the thing not just painted on.
Howard Sterndrive
I printed mine in the laser printer. Then laminated them in the laminating machine at work. I punched holes and fastened them with elastic cord.
Lasted about 3 years.
FH alumni
I was told by the CG that homeland security rules now require the registration has to be on the boat itself. The old trick of tying a board etc. to the boat with the numbers is no longer allowed.
cougarjim
Will the State decal stick and stay on a pvc inflatable without placing them on a board of some kind?
Thanks, Jim
nobrainsd
The CA state sticker will not stay adhered to a PVC boat by itself. I use a small registration plate holder. They come with a press on adhesive, but that is a semi permanent solution. I glued mine on with two part glue.
I still see a few inflatables with vessel number plates hanging off the side, but it is an open invitation to get stopped. Below is a quote regarding the new regulations for navigable waterways under Coast Guard jurisdiction (may not apply in some states to small bodies of water). The requirements for state stickers varies. CA requires the state sticker be attached directly to the boat. In CA it's got to be behind the vessel registration number while in FL it's in front. Check your local regs.
"Don't some states allow plastic boards to be legal?
The following is an exerpt from an Official Newsletter distributed by the head of the Vessel Examination Dept of the USCG Auxiliary. STATE REGISTERED VESSELS -- The Requirements Are: Use of Block Style letters and numbers only; Letters & numbers must be at least Three (3) inches in height; Letters & numbers must be of Contrasting Color (not outlined, shadowed or rounded); if the background is multicolored or patterned, a block out area of a single color may be required to facilitate readability. The Letters and numbers must be separated by the width of one letter or number - not including the number one (1) or the capital letter (I). Use either a blank space or a hyphen and they must be read from left to right. The validation sticker must be visible and placed within six inches of the registration numbers. Placement either in front of or behind the numbers is determined by state regulation. The Registration Numbers, Letters and Sticker must be PERMANENTLY ATTACHED and on the Forward Half of the Vessel. Adhering registration numbers and stickers on glass or plastic windows or using placards (signboards) are NOT considered Permanent and can no longer be used unless they are bolted or screwed in place on the hull or superstructure (including on dinghies). Signboards cannot be attached to railings. Inflatable boat manufacturers should be contacted for letters and numbers made of the same material / adhesive as the boat to attain permanency. Validation stickers issued by states can be adhered to metal or plastic plates and mounted on grab straps with non-reversible wire ties, but must be within 6 inches of the registration number and visible to law enforcement officers. Contact your state for guidance and acceptability. Above reviewed by the United States Coast Guard office of Boating Safety on: 12/16/04"
