How do you tighten the seawater pump
92rslt1
I have a 88 7.4 and I took the seawater pump off and inspected it and put it back on and I noticed the belt is really loose. How do I go about tightening the belt? There is no pulley or idler, it hooks straight to the balancer pulley.
Bt Doctur
Re: How do you tighten the seawater pump
If you look at the mounting bracket you will see the slotted area.
