how good to reed valves need to seal?
J JACKSON
I am in the process of rebuilding my 1988 E70ELCCA and some of the reed valves don't seal completely, i can push them closed with a pencil like the service manual says but they don't stay that way. They are only open maybe .010 in.
Georgesalmon
Re: how good to reed valves need to seal?
they are OK, they will close tight from the engine running.
You can usually see some light through one or more but not all of them.---0.010" is a bit much if measured correctly.-----Are there running issues with this motor ?
J JACKSON
it always acted cold natrued i think I am going to replace them whats another 50 dollars when you have gone this far, I think i am going try Chris Carson’s Marine Service reeds
Faztbullet
Good choice and will perform better......
