How many drain cocks???
chubbs
I have a 1992 yamaha v-6 4.3 engine. Does anyone know how many drain cocks are on the block. I found one on the port side. I would have thought there would be atleast one on each side of the block. Maybe one is hidden behind the starter but I can't see it. Does anyone know for sure.<br /> Thanks for your help
Re: How many drain cocks???
There should be Drains on Both Sides,.......<br /><br />It should be just ahead,+ slightly above the Starter.......<br /><br />I would also think that there'll be Drains on the Exhaust Manifolds.........<br />Somewhere just above the 1 you Found,+ the 1 you're Looking For............. ;)
