How many shift shaft rubber washers?
Kolar
1987 Alpha One stern drive, I'm in the middle of replacing the seals in my stern drive. I noticed when I took off the old stuff for the shift shaft there were 2 rubber washers under the shift shaft washer. Is there suppose to be only one washer or do I need to use the rubber washers to make up the height to the shift shaft washer? Here is a pic of what I took off (I bought the right parts, no worry)
nice rusted stainless washer eh?
Thanks
CRay45DB
Are the diameters of the rubber washers bigger than the steel washer? Mine are and it does not make sense.
Fun Times
Hi there, the steel washer should be on the bigger side. Also for future reference, please watch the date of the topics before posting to them.... For additional info about archived topics, please see the "Help Tip" at the top of the page ^. Thanks.:)
Have a look at these pictures for the larger washer,
Merc part number 29395 for WASHER size (.390 x 1.00 x .06) = Sierra # 18-4267-9, http://www.iboats.com/Shift-Shaft-W...5622720--session_id.404749565--view_id.173227
Mouse over to Zoom
Click to enlarge
Merc Rubber washer # 12-31266 or sierra # 18-2340-9 + SHIFT SHAFT WASHER for: #1R/MR (1/16" Thick) http://www.iboats.com/Shift-Shaft-Washer-18-2340-9-Sierra/dm/view_id.203851
Mouse over to Zoom
Click to enlarge
