How much does a 16' aluminum boat weigh
Status
Not open for further replies.
drice379
I want to flip my 16' aluminum boat over to paint. It's stripped out and the engine is coming off. It has about a 7' beam. Any idea how much that might weigh? Could a case of beer and a few friends handle it?
Re: How much does a 16' aluminum boat weigh
Ayuh,... Probably....
Is this the Football team, or the Cheerleaders,..??
lakelover
Should be a piece of cake, I flipped my 15' Jet Star by myself. (The windshield was off). You could probably even break out the beer first.
Note: My hull, when complete, weighs 415 lbs.
stone4141
I have a 16'ft Starcraft. With the floor out and motor off 4 guys can tackle it. Now with mine with the transom out and the splashwell out and basically everything gone except the hull I can move it myself but just cause of the length I would want another guy if I were taking it on and off the trailer. If your moving it any distance put a crowbar through the bow eye with a guy on each end and 2 guys on the back any you will be good to go. Oh and lastly I suggest beer before and after and maybe a little red meat it helps when you ask them to come back and flip it again.
drice379
Good point! I guess I will want it flipped back over some day.
Two people ;) Three is better! Just be certain of WHAT you are rolling the boat onto. I had cement blocks and when the boat was rolled the bow sat on one box and one block at each transom corner.
After I repaired and painted the hull it took 4 of us to roll it back over so we did not damage the paint job ;)
The 16' Starcraft SS weighs less than 700 w/o windshield consoles etc.
Woodonglass
two 20 yr olds flipped my 15 ft fiberglass hull onto my rolling cradle. It weighed approx. 450 lbs. I doubt your Tin boat weighs half that. Build one of these for $50 bucks makes things a lot easier when you need to move it around.
attachment.php
drice379
Love the cart idea. I'm definitely going to build one of those
mark1961
Ensign
My 15ft tin boat weighs 250kg (550lbs) with screen and deck but minus motor.....
MTboatguy
My Chrysler aluminum weighed in at about 450 without the motor...
FamillyJewelz
attachment.php
I know this response is 10 years old, but I was wondering if you still had the attachment since it’s not clickable.
Status
