How much is it worth?
samrcho
2006 trophy 1952 WA 4.3L mercruiser with unknown engine hours. Everything major is functional. Engine shutters after turing off ignition and takes few seconds to turn off. Spider cracks above rubber bumper, all around.
Minn Kota Riptide Ulterra 112 lb 72". Has a
Lowrance Elite FS 12 Fish Finder. Also, secondary hull transducer.
Get a survey done.
Would not spend that kind of money on a used glass boat without a good survey !! While the boat looks nice, there could be many thousands in hidden damage that only a pro could find. If the owner doesn't want to do a survey, then run away !
mr 88
Spider cracks are superficial, nothing you can do about it . Motor sputtering after shutting off could be timing off a tad . The 4.3s are good dependable engines. Personally not a fan of Trophy's , I would keep looking . The hull has no toe kicks , so you cant get your feet under the gunwales, that sucks for fishing . The cockpit is small , and with 3 people on board someone is always in the way . I/Os won't throttle down enough for trolling, so it's trolling bags , a kicker or a T-motor on the bow . The doghouse takes up prime real estate or if located under the deck ,gives you a higher center of gravity , which means rocking ,big time . It's supposed to be a fishing boat , yet most of the gear is on very high pedestal's . None of the fishing boats i own or buddies are set up with those sky scrapper's . Having said all that , I wouldn't pay more than 7- 8K for it . And a year later after realizing it wasn't as nice as a setup as i thought it would be , it'd be back on the market . This is my opinion, condensed version.
JimS123
To me it is worth zero. Not a boat I would consider buying. It's too old and a low end brand.
I see a lot of them for sale around here and they are fairly new. Now I’m starting to under stand why. Never been on one myself.
samrcho
Thank you for your input. I feel the same way about this boat.
