How restrictive are stock type exhaust manifolds?
SeanMcl
Just wondering if the stock exhaust manifolds are as bad as they look, or if the water cooling and the corresponding temperature/volume drop of the exhaust significantly eases the back pressure.
I have OMC log style heads, which are probably the worst of a bad situation, but I imagine the principle would hold true for all manifolds.
Re: How restrictive are stock type exhaust manifolds?
Yes,...
Lack of dedicated runners, aka; Headers is the problem...
SeanMcl
Do the old log style manifolds have flappers in them, or is that a newer development? Mine are from '74. The Seloc manual I have doesn't show them, but I still wonder.
HT32BSX115
Yes,...
Along with shoving it out through the prop too........
"Flappers" are usually on the "thru-hull's" on the outside, and in the Y-pipe, if installed......
