How to Determine Duo Prop "pitch"...
GilligansIsland
I had three set of Duo Props reconditioned and asked the guy to mark them (B2, B3, etc.) because I didn't know which were which.
When I got them home I see he marked each one for the actual Pitch and Diameter.
Is there a conversion chart of sorts so that I can determine what each set is?
Thanks.
Re: How to Determine Duo Prop "pitch"...
Volvo or Mercruiser ?
The inner and outter props will be different in their mounting splines, etc . . . then it is a matter of using the same pitch for inner and outter.
He has a Volvo.
I would call the shop up and ask them, they have the specs, they just gave you the wrong number.
GilligansIsland
Oops.
I see I originally posted in the wrong section. Didn't realize there was a props section... sorry.
