How to figure out prop pitch
wldman99450
I have 2 props for my boat (86 force 125), the one on the boat is suposibly a 19 pitch an i have a spare. I dont the pitch of. If there is a way to measure or figure out the pitch please let me know. Thanks
SparkieBoat
Re: How to figure out prop pitch
only a prop shop can figure it out. other than you could run both props and compare WOT RPMs and make a close guess.
Robbabob
Look near the hub on the end where the prop nut secures it to the shaft. That is the best place to find size and/or part numbers. Guessing will only lead to giving you bad information.
Ayuh,... The Best way is to read the numbers on it...
