How to find the gear ratio
mastercylinder63
Greetings, I have twin 1997 4.3ltr mercruiser motors with Alfa1 genII outdrives. the port side has a crack in the outdrive case, so I need to replace it. I'm not sure which gear ratio I have. Any help would be great, Thanks.
Re: How to find the gear ratio
Ayuh,.... You can pull the drive, 'n rotate it manually, countin' the turns, 'n mathematically calculate it,...
Or,...
Pull the top cap, 'n count the teeth on the 2 top gears,...
With the tooth count, go to the Adults Only section, 'n dig up the Merc info that'll tell ya what tooth count is what gear ratio,...
I would Guess it's either the 1.84:1, or the 1.65:1,...
Capt Ken
If its just the lower then don't worry about the ratio being they are all the same. The ratio gearing is in the upper. Now the kink , is it the counter-roatating engine?
mastercylinder63
Thanks for the info. Of course it's the upper portion that's cracked. The "Plate Zinc Anode tab area" is what cracked off the upper portion of the drive during Superstorm Sandy. I don't think that an aluminum plate can be heliarced since it's a cast piece.
longstand
Just wanted to say sorry for your lost regarding upper portion of your Outdrives.. Damm superstorm.. :laugh::facepalm:
tazrig
Wouldn't the port drive automatically be the counter rotating one?
