How to fix blisters & chips on the bottom of the hull
Fordiesel69
I am not very knowledgable at fiberglass repair, but on my boat I have blisters were the gell coat has flaked off. And a few X patterns here and there. Im sure the power washer did not help things. What is the best way to go about fixing these.
jbcurt00
Re: How to fix blisters & chips on the bottom of the hull
[h=4]Similar Threads[/h]
  • [h=6]Hull Blisters - need repair?[/h] By pec2402 in forum Boat Restoration, Building, and Hull Repair
    Replies: 36 Last Post: May 30th, 2013, 05:16 PM
  • [h=6]Blisters bottom re-gel?[/h] By green76 in forum Boat Restoration, Building, and Hull Repair
    Replies: 3 Last Post: May 24th, 2013, 10:46 AM
  • [h=6]hull blisters[/h] By Jeff62 in forum Tahoe Boats
    Replies: 5 Last Post: November 5th, 2012, 05:01 PM
  • [h=6]Bottom Blisters[/h] By mama12 in forum Boat Restoration, Building, and Hull Repair
    Replies: 3 Last Post: July 17th, 2006, 07:46 PM
  • [h=6]What causes hull blisters in Fiberglass/Gel?[/h] By craze1cars in forum Boat Restoration, Building, and Hull Repair
    Replies: 3 Last Post: April 6th, 2005, 07:56 PM
[h=4]Start w/ those ^^^[/h]
Not a simple fix.
Here's some more:
Blistering dilemma and local shop
Should I buy a boat with hull blisters?
blisters on hull of 28' chris craft
Hull issue..be worried??
Are these Bubbles on my Hull a Problem?
Blister repair
hull blisters
Blisters in hull gel coat. How do I fix?
Blisters on waterline
Blisters
There were 159 hits using the advanced search function from the resto forum home page. Searching: Gelcoat blister. Hull blisters, gel coat blisters, & etc may generate additional resources.
Post some pix if you'd like, but if you have a pervasive blistering problem on the hull, it will not be a simple fix. Look thru the threads I linked, Ondarvr is an industry professional that often answers blistering questions. His posts will be in most if not all those threads.
