how to get boat info on iboats.com
78ImperialT
alright...i know i have looked at boat info on iboats.com. i cant figure it out.
theres a way to look at boats by make model and year and they give a little info about each...like dry weight.
will somebody please point me in the right direction. im sure if it were a snake i would be a pin cushion, but i cant find it.
thanks!
howlnmad
Re: how to get boat info on iboats.com
Go to the forums home page and scroll to your manufactures forum. You should be able to link to that info from there
oops!
thanks!
i havent seen that feature ....but the guys here are really good....they have intimate knowlage with most boats.....
start a thread with your questions and the gurus here will have the info....or a link.
cheers
oops
In the manufacturer forum for some, not all when you open the forum
well follow these links as an example
http://forums.iboats.com/Starcraft_Boats once there look at the 3 underlined links above CREATE A POST box and they will lead you to more information.
Some basic information is available on many models
tashasdaddy
NADA boats. has the dry weight out of the factory.
78ImperialT
thanks for the help guys... i will try all of that.
