How To Install Hub in Prop
h2omansd
I've just purchased a prop and hub from iboats and expect it to arrive in a few days. Are any special tools required for installing the hub into the prop (aluminum 15X17 3-blade 992003)? Or, is it a no-brainer, simply push the hub into the center of the prop? I've never dealt with this before. Pls advise. Thx, sd
Silvertip
Re: How To Install Hub in Prop
Step 1: Follow the included directions!!
h2omansd
ok, was assuming there would not be any. But, am expecting the box in a few days and will look forward to finding some in there. Thx
tommays
Useing marine grease on the parts is a MUST in Saltwater OR it will become a ONE piece prop pretty FAST;)
Tommays
H2OMan, It is really easy. The brass splined part fits into the plastic part which fits into the prop part.....
rickdb1boat
