How to install new safety chains?
towdog
My safety cables have rusted out and need to be replaced. They are fastened on to the trailer through a single bolt. I believe the cables have plate almost like the end of a battery cable that fits over the bolt.
But the cables I am seeing on websites have loops at the ends. How do you fasten these onto the trailer? A really big, strong washer? Could someone take a picture of how these fasten ont the trailer?
These are the cables I am talking about:
http://www.overtons.com/modperl/pro...&r=view&from=grid&review=1#details_box_holder
Wingedwheel
Re: How to install new safety chains?
Yep, bolt and a heavy fender washer.
I always thought these created a couple problems.
1 - No way to effectively shorten the cable to keep the tongue from hitting the ground in the case of an uncoupling. That is what the chains or cables are for.
And no easy and sufficiently strong way to secure them on most trailers.
Ideally a large grade 8 bolt should run through the tongue, or a flange extending from it, then through the 2 cable ends or chains, then through a flange or the tongue on the other side, and capped off with a washer and locking nut.
I wouldn't entrust my boat, or some else's life, to a fender washer.
Hottip
For a few dollars more get the safety cables. They won't drag and they take a bolt thru the tounge like the chain.
towdog
Here is a diagram of my trailer
