How to lube cables
Sirrobin53
Here's the way I did it. Drilled a small hole in brass cable transition and used Abu Garcia silicote Reel Oil
Not bad, like the idea. I hope you can let us know how it's working after a couple seasons
Sirrobin53
Seeing as it is a built-in system I was hoping to get a little bit of lube in. Shift was fine. Throttle was a little stiff just off idle. Positioned the cable to have lube run towards the control. So far so good.
gm280
If it can run down the cable towards the other end, great deal. Any lude will be welcomed with those type cables. :thumb:
Sirrobin53
Thanks gm. I thought the same thing as well. To remove the cables will require a lot of disassembly that would not be much fun in the rain.
