How to Put Thru Hull Exhaust back to stock?
jetmart
I have a 5.0L EFI Merc with an Alpha Gen 2.
I have used the new to me boat 3 times and have already tired of the noise.
What do I need to get back to stock?
Here are pics of my current set up.
Re: How to Put Thru Hull Exhaust back to stock?
Ayuh,... Take the thru-hulls Off...
Get the missing Elbows,+ rubber couplings...
Then hook 'em back up to the capped off Y-pipe...
jetmart
Would you know part #'s and where to find elbows and couplings?
jetmart
I now understand how it should be plumbed but how would I go about finding out part #'s so I can order on-line?
jtmarten
Be nice if they had a video demonstrating the noise reduction.
jetmart
Ya that would be good. I figure if it cuts it in 1/2 I should be good. Looks like it cuts a lot of noise at idle which will be nice. Cheap and a quick install.
CascoBay
It should be cheap, all you need is the 90 from the looks of it.
