How to winterize a non-running Merc 3.0 engine?
kmf777
Hello all- I have a Merc 3.0 Alpha One that is not currently running.
My local mechanic took it apart to diagnose water in the oil and found I spun a ring in one of the cylinders which scored it and hence prescribed a rebuild...but no way I can afford it at this time. I'd prefer to buy a rebuilt but need to wait till spring to make a decision, meantime I need to winterize it.
How can I do this without it operational?
Help in New England!
Kevin
Re: How to winterize a non-running Merc 3.0 engine?
Ayuh,... Drain the water out of it......
Huh ???????? Is that actually what he said? Never heard of spun ring before. are you sure he didn't say a spun bearing?
Neither item wil cause water in the oil.
How much water was in it?
