hub kit
If the hub is modular, the manufacturer will suggest a replacement. If the hub is pressed in, a Prop Shop can repair it. What do you have?
1983 ercoa 21'
Not sure I think it is a press in which I have a press just trying to locate the correct hub kit.
1983 ercoa 21'
After a call to iboats I still don't know which hub kit I need.
after searching the internet i found some information but nothing to lead me to the correct hub kit . Guess I'll have to take a day off work and drive 200 miles to a prop shop
A lot of engine dealers have prop shop service. Sometimes then send it out, other do it themselves. It may cost a bit more for the dealer to repair, but you will likely need to make two trips to the prop shop.
