Hull cleaning products
Local46er
Just purchased a used boat and it was in the water for the summer, the Marina it was docked at didn't have the cleanest water. Now there is a nice sum line on it. Tried soap and water but very little luck. Any products to make this process a little easier on the arms and shoulders. It's a fiberglass hull.
Thanks for looking.
welcome aboard.
try sno bowl toilet cleaner
thumpar
I use Starbrite instant hull cleaner. You just wipe it on with a sponge and then hose it off. No elbow grease required.
RGrew176
Some won't agree with this method but if it is a white hull I used on my last 4 boats Muriatic Acid in a bug sprayer. I sprayed it on straight up and rinsed as soon as the discoloration disappeared. Worked very well for me. No elbow grease needed. Spray and rinse off and done.
Muriatic acid is Hydrochloric acid which is the same thing as the Sno Bowl toilet cleaner.
RGrew176
That is true but straight up muriatic acid works a lot quicker than Sno Bowl. I have used both. Like I said above not everyone would agree with using muriatic acid straight up but it works for me and I see no reason to change my method.
four winns 214
Wal-Mart sells an oxalic acid hull cleaner in sporting goods for $7-8 if you don't want to roll your own. Most Wal-Marts, but not all, carry it. As mentioned, oxalic-based stuff works like magic and a little goes a long way. One bottle will do the entire hull on a 21' boat. Do rinse well any painted surfaces it touches.
Muriatic acid is typically 2 to 3 times more concentrated than sno Bowl. Probably just have to be more careful using it and not let it sit as long.
thumpar
I was just looking and you can get 2lbs of 99% to mix yourself for $8.70 with free shipping on Amazon. That should last into my next generation.
BRICH1260
I use the WalMart stuff too, just replace the screw on cap with a trigger sprayer. Like others have said, basically spray it on, no rubbing needed. You do have to watch your trailer, especially if it is aluminum. I wet my trailer down well before spraying and rinse it well when done.
I looked back at what I bought. 20lbs for $27. When I got it I realized I will never use half of it in my lifetime.
I use Attwood biodegradable hull cleaner from Walmart. $6.95 a quart
Pour 1/2 quart in sprayer and cut 50% with water. Costs me less than $4 per season and I don't need a hazmat suit and a EPA application certificate to apply it.
It's all about the concentration. For my application, removing tannic acid stains, I get away cutting the product's concentration in half. That's half the number of dead lung tissue while doubting the "value" of the bottle of cleaner.
I can make mine any concentration I want for abut 1% of the cost of the bottled products.
