Hull ID card
JD in Milwaukee
I've got a 1979 22' Islander with no hull id card. How do I get a replacement? Can I call Starcraft and get a duplicate? It's an i/o, what is the max horsepower for the hull? Thanks in advance, John
dozerII
Re: Hull ID card
You won't have any luck with Starcraft, their records for anything earlier than 90 are all gone. Best bet is to get the info from another islander owner and contact North Beach to see if he can make you one, he does a geat job on them.
Glen
JD in Milwaukee
Re: Hull ID card
Thanks guys.
Can anybody fill in these blanks?
22' Islander I/O
MAX HP
MAX CAP
MAX WEIGHT
Re: Hull ID card
On my 1983 22' Islander, max hp is 175, total persons 8 or 1500lbs, or max wt of 2000lbs including persons and gear.
Airshot
JD in Milwaukee
Re: Hull ID card
Thank you sir. Is yours an I/O? I thought I read OB's and I/O's were rated differently?
Airshot
North Beach
Re: Hull ID card
JD I would copy Airshots tag if I were you. That sounds about right since we dont have a 79 brochure. I have a batch of id plates that will probably be ready on Tues or so but I can still get you one. Send me a PM.
magnumdeke
Re: Hull ID card
Those look really great, but I don't have one to start with to make a copy from.[/QUOT
1976 placards not the best pics but it is a start, Enjoy:)
JD in Milwaukee
Re: Hull ID card
Very nice, thanks. I don't see a max hp though? Did I miss it or can I throw in that 800 cube Sonny Leonard hemi headed, big block chevy I've got in the garage!
Re: Hull ID card
Yes, I believe they are decals.
I ordered mine on Thursday, so I will see too.
JD, hp ratings are not required on boats over 20' in length.
I only recall looking at the rating plates in i/o boats a few times, and they did not have a hp rating, even on some 18' boats.
