Hull in a very bad condition... need help
tagggg
Hello
Firt of all, i will make a real restauration thread but now, i'm little bit discouraged. And, i'm a french canadian, and not really good in english. :redface:
I've just bought this boat. But what surprises. The hull seems in very bad condition and I dont know if its possible to do something with it.
assume that the whole bottom of the hull is in the same condition.
I have the time and budget for the restoration of the boat so this is not a problem. But you think that product should I use to do a nice job?
thank you for your help
tagggg
DANZIG
Re: Hull in a very bad condition... need help
Not the best of pictures. It is difficult to see what you think the problem may be.
Near as I can tell, you have multiple layers of paint flaking off and a dent???
Or is that pitting holes in the hull??
oops!
welcome to i boats eh? :)
that is paint coming off.
what products you use depends on how well you want to do the job.
but the first thing you have to do is flip the hull and sand all the paint off....then we can deal with the damage
cheers
oops
tagggg
My problem is the multitude of small holes in the aluminum. (pics no2) nad i don't know what's the best product to make a perfect job. I know to sand all the boat before the paint and i know the glucit use in the boat. But for this small hole, jb weld Marine tex, other ???
Woodonglass
Welcome to iBoats!
You might want to check out this product. It really works well in the repair of holes in aluminum. You must sand and clean the surface really well before applying metal 2 metal, but if you do it will never come off and it will seal the hole permanently. YOU will have to paint it because it is not 100% water proof
http://www.evercoat.com/productDetail.aspx?pID=37
You might investigate this product for painting the boat once the repairs are all done
http://www.epoxyproducts.com/aluthane.html
I'm just sayin...:D
ondarvr
According to the MSDS for the Ever-Coat, its polyester resin with talc, so the bond and waterproofness (not a word) would be a little suspect for marine use.
If the holes are from now unused screws or something similar, then put a nut and bolt in it with a little 3M 5200.
If they're from corrosion its more difficult because areas around the holes are most likely bad too, plus other areas you can't see (riveted overlaps, welds, etc), so the entire hull may be weakened.
