Hull question
Chris611
I am working on my boat, a 21 Conquest I/O. I notice that there are no drain holes for water to drain from the lower rear sides of the boat, under the floor, into the bilge. The engine compartment is fiberglass up to the carpet. It has openings to the front, but not to the sides. Just wondered if the rear lower sides of the boat are watertight or if they drain somewhere else?
Thanks
Chris
Texasmark
Re: Hull question
One way to find out. While it's on the trailer, put some water in it. Pull the available drain plugs. You should have your answer in short order.
Mark
