Hummingbird download
Skipb48
This might be a stupid question, but I'm trying to upgrade a Hummingbird Helix 7 and the directions don't tell me if I should open the bin file that is download it from the Web before I put it on the SD card. Advice ? If I open the files and put all the open files on the SD card and then insert that into the hummingbird unit, does it automatically know which to install to the unit?
Thanks
Thanks
HELIX Software Update Instructions​
NOTICE! To ensure a smooth update process, please keep the unit powered on until the update is fully completed. Interrupting the power supply during the update can result in system instability or data loss. It is crucial for the integrity of the update that the unit remains operational throughout the entire procedure.
Before you begin: make sure to remove any other card that may be present, such as a LakeMaster, Zero Lines, Navionics, etc., from the unit before initializing the new update.
  1. Install the microSD or SD card with the updated software file into the control head card slot.
  2. Power the unit on.
  3. The control head will recognize the new software (recognition may take several minutes) and run through a series of prompts to confirm the software installation.
    1. You will first be asked if you want to install the displayed version. To continue, answer with "Yes" (RIGHT Cursor key).
    2. You will then be asked if you want to abort the update in the chance you proceeded by mistake. To proceed with the update, answer "No" (LEFT Cursor Key).
Skipb48
Yeah I understand all that, but is that the bin file I'm putting on the SD card or just the contents of the bin file?
Alumarine
I've always just copied the firmware bin file to the sd card.
How are you opening the bin file to extract files?
HillbillyGuy
I just went through this one a helix 5. Having 30+ years in tech I got pretty frustrated attempting to upgrade my unit. Here is what I found ….
format the SD card in computer.
place SD card in helix before copying bin file To SD card. Power up unit.
remove SD card and copy bin file to SD card.
now insert SD card in helix again and it permitted the upgrade.
I discovered the helix unit sets some parameters on the SD card that need to be there the first time it is inserted in the units
I also found out in my case the card needed to be inserted with the helix already powered up.
wish you the best in your attempts
