Hydraulic trim pump issues-
rocket1968
I6 from 1975. FInally got the pump off and tagged/docmented wires. Should this have come off by two bolts that hold the bracket on or the four bolts that hold the pump onto the bracket? When i tried the two screws for the bracket they spun the whole bolt. Are these the ones you need to grip the bolt and move with nut with a open end?
Question: Now that I have this thing off, I dont see where it was leaking. If I start opening it up will it be found? Solinoid works, I was getting a bunch of leakage and I know it wasnt either line and it was leaking out of the bottom.
Can this be bench tested? How is that done?
Help me get the boat back in water...thanks for your help.
How do I attach photos? I have photos avail.
Re: Hydraulic trim pump issues-
Ayuh,... Down in the "Technical, Non-boating" forum, pinned to the Top, are "How Tos" for postin' pictures...
