I got problems with my wellcraft nova 21
yoyins69
hey I just got a wellcraft nova 21 1974 is in bad conditions and I need help fixing it I have to fix's the floor, the paint is bad conditions the ex owner paint the boat him self so trust me is bad the cabin is perfect and the engine I had to fix it at least well I like it but I got to fixis before its the water so her I go....
nova23zz502
Re: I got problems with my wellcraft nova 21
You shuld use the west system and be ready for rotted stringers. Good info on you tube.
jonesg
Pretty engine, cabin, trailer and bright paint job, but none of that will matter if the stringers and transom are wet and rotting.
If the floor is soft the stringers will probably be rotted out, foam is soaked and transom too. The last place rot shows is in the deck, they rot from the hull ...up.
skargo
Banned
You should look at post dates, this is a 7 month old thread. The author hasn't even posted on the site since December. ;)
Just friendly advice...
Ayuh,.. It took that long for somebody to Decode whatever the OP said.....:rolleyes:
skargo
Banned
I cut him some slack since he's from PR and might not have the same grasp on English as you and I ;)
nova23zz502
Lets keep this post going. My floor in my 1995 23 nova was shot bad in one side only. All else is fine. I am doing the project as we speak. :D
No. Please nova23zz502 start your own thread and do not hijack someone else's thread ;)
