I HATE AUTOMATIC BILGE PUMPS!
Lou C
The best auto bilge switches I used were the Sure Bails with the Mercury switches. First one lasted 12 years and the one I put in after that is about the same age now. I bought a spare back then so if this one fails I have a replacement. They don’t make these anymore as far as I know….
Horigan
Gee, I currently use a electronic-sensing auto bilge pump. It has no float to get jammed and they last 5 years or so, before breaking. Every of those pumps that I had (say 6), failed in the electronic water sensor module. The pump would still work on manual.
I transitioned to the auto-sense pump, because a piece of crap got under the float, and guess what happened?
How do you test it?
Instead of bashing bilge pumps, why not fix the water intrusion issue, then no pump worries... My bilge pump is factory original and still works fine, 34 years old.....I don't see the problem....
Lou C
Moored/docked boat always get rain water in the bilge even with waterproofed covers.
Jeff J
True, but I think a lot less than what gets in a ski boat during a active day on the lake.
Lou C
Agreed
the odd thing is that I find with my boat it gets less in the bilge from rain water when it's actually out on the mooring than when it's in the driveway.
"How do you test an auto sensing bilge pump?" They run every 2-3 minutes for a second or two to see if there is water to pump. So wait 3 min and listen for the pump to come on.
Those pumps are load sensing , the controller can sense the load on the motor and thusly knows if it is pumping water or not ,reliable enough but down side is the sensing pulsing of the motor. Any partial aeration of the pump can confuse them .
As for testing all you can really do is wait till it pulses and if its dry you should only get the pulse if there is water (tip a bucket full in )then the pulse should turn into a continuous run untill the water is gone, it may well run for a bit after the water is gone just to confirm ventilation 🙂
That sounds like something that is just waiting to go bad !
I think a simple float switch as long as not prone to fouling with debris is simpler and better!
If there is that much debris, perhaps the boat needs cleaned more often...been a boat owner over 60 years and have never had these issues with a bilge pump....don't even know anyone that has...no offense to anyone, just a problem I have never saw before...
I mostly delt with load sensing on F&P dishwashers and the only real issues we had was either pump inlet filters clogged with crap ....honestly some people treat their dishwashers like garbage disposal ....or peeps using detergents that caused foaming ,either of which messed with the load sensing and the thing would flood .......ironically tripping a float switch in the base pan that turned on drain pump. This float switch usually only failed due to mice getting zapped and attracted maggots that got under the float and triggered false flood faults . However once water was in the base pan the drain pump couldnt clear it .
Have bilge pumps in bow and transom compartments.
Both pumps on traditional (Rule) float switches controlled via a three way switch (on/off/auto) with an “active” light to let me know when either pump is active.
I was religious about turning the switch off with the boat out of the water the first couple of years. Got lazy after a while and just left it on “auto”.
Burned up one motor and a battery in all these years. Forgot to turn the switch “off” and pull the drain plug at winterization. Water froze activating the transom pump.
! Now a days you can get water monitors that send signals to your cell phone line.
If your marina has a decent WiFi you can most likely set up to get an alert to your phone when water is detected and you can send a signal to turn on and off the pump.
If I moored a boat this would be something I’d look into.
The last year we had a moored boat i was thinking of this.
