I need help! lost all power
tds1774
I have an 86 bayliner capri w/125 force, finally got it running, now my switch dosent work. I can turn it on and jump the solinoid it fires right up, have all dash lights. with the eng. off, turn the key and nothing. Im lost on this. i've looked the wiring harness over for fuse links, none. checked the fuses, all are good. connections were a little corroded, cleaned them but no help. was working fine while I was working on eng. when I got eng running I let it run for about 30 min on hose shut it off tried to start again and nothing.
another question I have is; are the little diaphrams (3) in the fuel pump replacable? do they come in fuel pump rebuild kit? I was able to get them out once, 1 was working good, the other 2 were hanging up, I worked with them a little and got them working, then they hung up again. took it apart again got them working again, but I cant get 1 back out. I dont want to damage it if its gonna be hard to be replaced. my fuel pump is the figure 8 looking type, sorry but htats the best way I know to describe it.
jaybirddog11
Re: I need help! lost all power
The three "diaphragms" are called check valves. I just replaced mine at a local mercury shop. They had them in stock.
have you checked the wiring on the ignition switch.?
its either that or the starter solenoid
