Mercrusier 6224726 is serial off 83 16ft cheeta.what kind motor you think is hooked to it
boatermarquis Petty Officer 2nd Class Joined Apr 15, 2014 Messages 117 May 15, 2014 #1 Mercrusier 6224726 is serial off 83 16ft cheeta.what kind motor you think is hooked to it
D dubs283 Vice Admiral Joined Jul 27, 2005 Messages 5,346 May 15, 2014 #2 Re: I need info on outdrive that serial number comes up as a 45/50 hp mercury outboard, not a mercruiser where are you getting this nummber?? Last edited: May 15, 2014
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,494 May 15, 2014 #3 Re: I need info on outdrive Always love these tough questions. If you tell me the number of cylinders it has I might take a guess
thumpar Admiral Joined Jun 21, 2007 Messages 6,138 May 15, 2014 #4 Re: I need info on outdrive Most likely a 120 or 140. The biggest difference externally is the 120 has a pulley and the 140 has a balancer.
CaptainMak Petty Officer 1st Class Joined Apr 28, 2012 Messages 294 May 16, 2014 #5 Re: I need info on outdrive maybe some photos of the powerplant ? cylinders ? inboard, outboard, stern ?
