i/o merc throttle/shift control replacement- help!
piratedude
Need some advise re replacing the top mount throttle/shift. had a quick silver 3000? junk. need something that is solid and not flimsy and easy to install - any input? this went to a 350 i/o bravo 2.
Re: i/o merc throttle/shift control replacement- help!
Ayuh,...
Google up I/O Controller,+ take your pick....
Teleflex has bought up most of the builders... You might start there...
Roman S
I have one of the recent CH1700's from teleflex. It is a nice unit and they have made improvments since it was first introduced. While at the control, take a good look at all the cables. Good time to change them out also, if they need it.
RS
