- Joined
- Jul 18, 2011
- Messages
- 19,169
Well, I know that I have aged . . . I can no longer contort my body to reach under the engines to check the water intake hose clamps. As I was trying to do so over the past few days, I said to myself . . . . "well that just perfect"
I used to not mind maintaining the I/O engines, but it is starting to wear on me. I was also thinking . . . 'it's good that the gimbal bearings and U-joints are perma-lube type, because now I don't have to remove the outdrive each year' . . .
Anyway . . . I plan on working on the bracket (or hull extension) at the end of this season, then see about having a re-power shop take care of the OB's.
