- Joined
- Jul 23, 2011
- Messages
- 52,521
outboards do have fuel coolers and oil coolers. however for the most part short of the Seven Marine 557/627 outboard motors, no, there isnt a heat exchanger.
Cpule screws for throttle linkage. Olny drawback would be if changing brands but still easier. And when I redid my floor that has its own space so pulling will be easier than normal.True 4 bolts and it’s out. With I/Os you have 2 worries the engine & the transom/drive. That’s why some mechanics call them “double trouble”.
I just spent 20 minutes with a video about 7 marine. Never heard of it. Pretty awesome.outboards do have fuel coolers and oil coolers. however for the most part short of the Seven Marine 557/627 outboard motors, no, there isnt a heat exchanger.
Too bad Volvo Penta bought them to squash themI just spent 20 minutes with a video about 7 marine. Never heard of it. Pretty awesome.
I made the twofootitus upgrade four years ago. Merc 180 hp 4.3LX to a VP G5 4.3 250 hp.The only advantages of I/Os are the less expensive simpler GM marine engine and swim platform, it is a lot cheaper to repower an inboard.
I grew up with Chevrolet small blocks and know them well but as one of my former mechanic friends said I’d rather have my Chevy small block…in a Chevy!
About 3 years ago my brother moved back to my area (North Shore Long Island NY all salt water) and wanted a boat again. He wound up with a 2020 Chapparal 20' with the Merc 4.5 V6. Very nice driving boat, nothing to complain about there, but the engine accessiblity was bad except for oil changes and the quick drain. Any other repair would have been a horror show, and there's the cat converter exhaust which in salt water is such a financial liability, I will NEVER have one. Boat was fine though till one day (moored in salt water) it started running hot, the Merc Guardian system kicked in to limit RPM. All it was, just a bit of marine fouling, I showed him how I hang over the swim platform and rod out the water intake holes in the lower unit. But at that point he could see the writing on the wall and traded it on a similar boat with a Yamaha 4 stroke. There is a swim platform, just not the full width one you can have on I/Os.I made the twofootitus upgrade four years ago. Merc 180 hp 4.3LX to a VP G5 4.3 250 hp.
I compared several brands of 18-20' BRs. In all cases where the boat offered both I/O or O/B, the O/B model at the same power was considerably more expensive. Also the O/B version offered less hp than the highest hp I/O.
So I went with another I/O. Family would have disowned me if I didn't get a swim platform.
Now I'm stewing in my own juices for the decision. The VP is shoehorned into a Regal 1900 ESX. Engine pull requires removing the one piece exhaust manifold/risers. Last summer I gave up changing #4 & #6 plugs to lack of access. I'll give it another go in the spring, but I may have to pull the starboard manifold to get the job done.
Most decisions involve trade offs. ....then you live with them.
I just double checked and it looks like you are correct, SST for inspected vessels only. While checking, per ABYC H-5 and USCG, the capacity rating may need some consideration. Out of curiosity, does your vessel have a capacity plate from the manufacturer on it now?The aspect of stability has come up to some extent. Essentially the weight of the engines, although less than their I/O equivalents is positioned higher on the boat.
My understanding is that the SST requirements apply to commercial vessels, not recreational vessels.
I googled the following explanation . . .
"No, recreational boats generally do not need a formal, complex stability proof test like commercial vessels; stability requirements for recreational boats focus more on proper PFDs (life jackets), safe loading, and general good seamanship, while the USCG Simplified Stability Test (SST) is for specific, smaller commercial passenger boats (under 2 decks, meeting other criteria) and large commercial vessels need full incline tests. Recreational boaters should focus on carrying sufficient PFDs, avoiding overloading, and understanding their boat's behavior."
I probably can (should) calculate the change (vertically) in the Center of Mass just to see how much it will change.
I calculated the horizontal change (9" towards aft), yet with the added planing surface (42"), it will be more forward than before from a planing perspective.
It has the "Yacht Certified" capacity plate. The manufacturer has published the maximum power as 760HP.. . . Out of curiosity, does your vessel have a capacity plate from the manufacturer on it now?
No, it becomes a 'make it my own' boatWith this much modification does it become a home made boat?
