I/O (Sterndrive) Conversion to Outboards
flashback
Way I see it, your bolt threads will be coated with putty, may as well just run the nuts up and call it good. I've mostly experienced galling when removing the nuts not so much on installation.
I also think you may want to put a spacer type border, a tad less thick than the spacers, around the big access holes so the putty doesn't get squeegeed out too much.
If it's not grinding, it's drilling . . .
I went through several cobalt bits . . . amazing what a sharp drill can do . . .
It reminds be of way back, when I was a young engineer in an electronics manufacturing company. The VP said "the printed circuit board fabrication line was having problems . . . go check it out" . . . A couple of weeks later things were running smoother. He asked what the solution was . . . I said "drill bit sharpening. . . . :LOL:"
Anyway, I digress. After several days . . . here are the bolt holes.
34 bolts on the transom faces and 10 bolts overhead . . . 44 total. I may add a few more once the extension bracket is installed. When I had 80 bolts in the plans, the naval architect told me I could go with about half that number. So it is . . .
I have installed/removed the extension bracket a several times over the past few days. Each time I check the alignment to make sure the thing is not 'walking around' on me. Looks good and repeatable.
That will be important when I install the E-B for real, but I will check it then anyway.
There have been a couple of warmer /sunny days this week. So, I got the side supports for the transom glassed. I did 2 layers on both sides (4 layers total) 'wet-on-wet' and wrapped them in plastic to hold the glass tight to the core pieces while they cured. It worked out pretty good.
Each of the 3 transom support 'knees' have over 2 sq. in. of fiberglass in their cross section, so conservatively 30,000 lbs of strength in each of the 3. (y)
Lpgc
Edmund Fitzgerald and British ship Hood. Come to mind.
Been re-reading the early parts of this thread because I'd forgotten some of the reasoning for converting from inboards to outboards. Sorry for going off subject a bit now, couldn't resist saying my grandad was on HMS Prince Of Wales when Hood was destroyed so saw it happen, one of his friends was on Hood at the time and was one of the 3 survivors. Grandad played cards with Churchill and Roosevalt on Prince Of Wales and was on P.O.W. when it too was destroyed by the Japs. At first he and a few others laughed at the planes, especially when some crashed into the ship's 18" thick armour exploding but causing only minor damage, not laughing so much after a torpedo bent their propshaft and rudder and the bent shaft broke all the shaft seals between watertight compartments though. I wonder if it would've turned out differently if they'd stopped the engines after the propshaft got bent because that would've prevented flooding from the rear going forwards, it probably wouldn't have listed and other torpedoes might all have run into the armour belt instead of the thinner areas of ship they hit due to the listing.
If P.O.W had outboards there wouldn't have been any flooding from a bent propshaft :LOL:
Jmunk
I find it amazing how strong fiberglass and resin can be when combined.
There you go ... ALL boats and ships should be powered by outboards ... 4 stroke or 2 stroke?????? ;)
Milestone date . . .
The extension bracket is now installed on the boat.
It's a good thing I practiced this a few times. . . . something always goes haywire. The day started out cool & cloudy, but the sun was forecast. I started at 9:30 . . . and all of a sudden the sun came out in was shining on the port side of the extension bracket. And of course the putty on that side started to harden up . . . So, a little bit of 2X on the speed of things and I got it installed and clamped in so the putty was still able to ooze out the sides.
Game-time decision to do the area underneath the edge of the swim deck afterwards, which worked out well. I could have used more putty and started earlier in the day to have more working time. I activated 3.5 gallons, leaving about 1 gallon for touch-up and follow on work. It seems like a 5 gallon pail only gets you 4.5 gallons of putty . . . :cautious:
This will sit for a few days to really harden up. A lot of the bolt holes got filled with putty and it set up quicker that I was able to get to them, so I wouldn't have to drill. . . . No worries . . . I'll just drill as needed.:unsure:
Lou C
Just amazing Ted, your project is an inspiration to us all and beyond that, any job I have to do, becomes a lot smaller/less challenging etc.
I was thinking about you on Wednesday when I was in Boston for my son’s graduation. It was supposed to be a crummy day but thankfully it turned out to be very nice. I was worried I would be sitting in Fenway for 4 hours in the rain. If I remember correctly your on the books for the motors to be installed pretty soon right.
It won’t be long now and you will get to enjoy the fruits of your labor.
The bolts have been challenging . . .
Many of the bolt holes filled with the deck putty when the extension bracket and boat hull were mated. The good thing is that the putty was squashed as it should have been. The bad thing is that I need to re-drill most of the bolt holes . . . most of my Cobalt drill bits are dull from the various drilling I've been doing., so those will be on order. Here are some of the more interesting shapes from the putty 'oozing' out of the bolt holes . . .
I also fabricated some stainless bar stock to reinforce the top set of fasteners. . . but . . . it looks like some of the bolts are too short. So, I'll need to order some more . . . 1/2" longer should do it.
When I got to this point, I stopped tightening the bolts and did not do the other side . . . pending some longer bolts.
I could never get good results with a drill doctor. It’s probably operator error. I still hand sharpen and it works well for me.
Maybe some day for a Drill Doctor . . . but in the meantime, Amazon early AM delivery (5:48 AM to be exact) comes through :LOL:
Re-drilling 18 holes . . . what fun. The hull & deck putty is a lot stronger/dense than I expected. I really had to lean on the drill to get the bit(s) to bite.
Anyway, I got 18 bolts done today, to make a total of 36 bolts (+/-) that I have installed . . . about 10 more to go. Those will have to wait, as I'll be traveling here and there the next few weeks.
Now that I have the extension bracket installed, here are a few pictures of how it looks (less fairing compound and gelcoat :LOL: )
The engines will be set back about 28" from the swim deck
Most of the extension bracket tucks under the swim deck . . .
I still need to do the scarf joints. Right now on the bottom edge, where the planing surfaces join together, is a foam 'gasket' that I invented for the joining process. (you can probably see it in a few of the pictures). Its purpose was to keep the hull & deck putty confined to the intended contact areas and prevent it from oozing out the bottom and falling on the ground. Amazingly, it worked !
