I/O with RWC question
Bay-185
I have a Merc. 3.0 with a Alpha 1 drive that is RWC. Does anyone store it for winter with antifreeze in the RWC? If so how do you put the fluide in and how do you keep it from draining out the cooling discharge in the drive?
JB
Re: I/O with RWC question
Gone to the Mercruiser Forum.
Completely Draining the cooling system is Easier,+ in My mind Better than using Antifreeze.......
Wotknot
....an abbreviated version of what Bond-o just said...
"air doesn't freeze"
Bt Doctur
? how does air keep the cast iron from drying out and scaling and plugging everything up.
