I ordered hub kit # 835257K1 but received part # 835257A1?
weider1717
Is it the same or what? This is for my 1985 MR outdrive which is 99% alpha 1 gen 1.
should I send it back? bought it new off ebay.
Re: I ordered hub kit # 835257K1 but received part # 835257A1?
Ayuh,... Go Try it....
Fun Times
No need to send 835257A1 back it is the same part, Just in a different box is all. The (K) Would have come in a black box is all, And that is MerCruisers newer brand with their name on it, The other style is (Q) for Quicksilver, They are the same exact parts. And below you can see your (A) has now Superceded to (Q).
Part Number 835257Q1 Superceded From 835257A1 And The (K) box will stand a lone sometimes when looking things up.
Also some parts suppliers will now start sending the (K) box from MerCruiser once they run out of (Q) and (A).
MerCruiser dealers have a choice when ordering from MerCruiser They can go with either the Quicksilver or MerCruiser style boxes to display in their ShowRoom. So your good to go boating still.:)
weider1717
No need to send 835257K1 back it is the same part, Just in a different box is all. The (K) should be in a black box, And that is MerCruisers newer brand with their name on it, And the old way was (Q) for Quicksilver, They are the same exact parts. And below you can see your (A) has now Superceded to (Q).
Also some parts suppliers will now start sending the (K) box from MerCruiser when they run out of (Q) and (A).
thankyou!
