I think I have the wrong throttle bracket
candrive55
Hi I have a carbed chev 350 with a holley dual feed 600 marine carb. The bracket on the intake manifold that holds the throttle cable is to close to the carb( or so it seems) and I am not getting enough movement on the cable to open the carb plate 100%
I have the wrong cable bracket
OR..I need a very long throttle bracket on the carb..The end of the cable that hooks to the carb wants to be about 2 or so inches farther forward than in this pic
very sure the cable is good and so is the contoller
The pics are not mine but taken from the internet
candrive55
Re: I thing I have the wrong throttle bracket
ok lets try this then does any one have a pic of a holley four barrel used with that cable bracket. Dont want to start jerry rigging it
Thanks
looks like the right bracket, maybe wrong carb. here are pics of my 271C with the same bracket/cable
candrive55
well looks like we both have holleys and the same cable. I just dont get it
Thanks Scott
is yours a mechanical secondary or vacuum secondary carb?
candrive55
pretty sure its vacuum secondary carb
candrive55
I know being a vac that the big plates dont open. But its the front smaller ones that I dont open 100% unless I jerry rig a 3.5 inch long bracket off the carb.but that lifts the cable too hi in the air and makes for a bad angle
can you change the control end?
candrive55
If you mean up at the helm I could. Why what ya thinking.
Is there other cable brackets for this that I dont know of. Cant find anything on it.
If i could move the throttle cable bracket back about 3 inches or so it would work. But that goes aginst every pic I have seen of this set up.
ok i found a pic of something that might help where can i get this bracket that is on the carb in this pic
what you have is the standard VP cable bracket. there may be adjustment on the helm end to get you more stroke.
take a picture of what you actually have vs internet pictures. it would help us to see exactly what you have.
candrive55
I will take pics today. I am getting full stroke of the cable. thanks For helping
candrive55
ok got the pics pic one is at idle
pic two is full throttle( bad angle on cable up in the air)
pic three shows How long this thing is
controler is good
cable is good (moroso 33)
what gives?
Ayuh,.... What's with all the junk bolted to the carb actuator,..??
Move the cable end closer to the pivot to lessen the angle, 'n shorten the stroke...
candrive55
Good God. Could it be that easy. If so I will have to change my user name out of embarrassment. Will know more tomorrow
agree with Bond-o, remove the carp bolted to the carb.
mfsb
That engine came with a rochester Quadjet spread bore carb. Your problem stems from trying to retrofit a holley to it. You may get it to work right, however your carb should be a direct bolt in line up item. I have the same egine in my boat, I swapped the block for a 350 and it is running like a champ. I can provide photos if you would like showing what mine looks like. The model of carb is a 4MV if you are interested in getting the proper carb for that engine.
Volvos used Holley carbs on many engines.
