I6 instead of I4
KellyC
Hello all, I have a 67 Starcraft Islander with a 4 cyclinder in it with a merc outdrive. I was wondering if anyone here has replaced thier 4 banger with a I6 and how hard would it be to do. I am asking because I would like to replace the outdrive with a newer one from the motor back, I have found several good deals on boats with I6's in them and good outdrives. But not sure how hard it would be to do the install for the I6. Thanks in advance for any and all help from the oh so wise ones on here. have read lots of good advice that has been given here and I think that this forum is the bests place for help that a person can find.
Kelly
Re: I6 instead of I4
Ayuh,... Going that route, all ya gotta do is reposition the front motor mount....
It really depends on which 4 cylinder engine you have. In 67 there was Renault, Mercedies, Rover, and GM 4 cylinder engines, along with different drives and transom shields that the 6 cylinder will not bolt up to.
attachment.php
attachment.php
Ayuh,... While I've never run accross the Mercedes, or Rover,...
I believe the transom cutout is the same, or atleast nearly so...
KellyC
Guess I should have been a little more specific, it is a merc 120 so I believe that it is a chevy engine. Sorry I did not include that Don.
I am hoping that it is pretty easy as you are thinking Bond-o, that would be really sweet.
