ice auger engine problem
PmDavis300
tuned up an auger and cleaned the carb. it ran great when i had her warmed up and adjusted. now when i start it, it doesnt like to stay running at cold idle and when you pull the throttle back quickly to wot it dies. if you ease it into wot it will run great. im guessing carb problem... did i adjust the mix screws wrong?
Re: ice auger engine problem
Ayuh,... I'm guessing you're Right...
It could be mis-adjusted, or some Crap In the carb...
