Idle Adjust Mercruiser 3.0L
RSHOOTER
I have a 2007 Glastron GT-205 with the 4 Cyl. Mercrusier.
This year the idle seems low in neutral about 500 rpm. The engine runs fine but it can once in a while stumble when it's put in gear due to the low RPM.
I don't want to mess with the mixture screws. Can I add maybe 200 RPM by adjusting the cable? Which direction?
Thanks.
jerryjerry05
Re: Idle Adjust Mercruiser 3.0L
Don't ever mess with the mixture screws. Don't adjust the cables unless you know what your doing.There is an idle set screw you can adjust.Use a tach/dwell instead of the on the boat the one you have in the boat might be off. Jerry
RSHOOTER
Thanks Jerry. I think the mixture screws require a special tool.
Where is the idle adjust screw?
