idles great will not plane out
dguess
I have a 3.8L 1985 OMC that idles great sounds great and runs great in the no wake zone. When I throttle it up the nose goes up the tack reads 2000 RPM but that is all she wil do. I have had the carb rebuilt, the timing checked, cleaned and re[placed all the filters and screens. I am not sure but have a fews ideals but would like second opinions.
1) Fuel pump cant handle the volume at higher speeds
2) the coil
any help would be great.
Re: idles great will not plane out
Ayuh,... Sounds like Fuel delivery... Fuel pump, or a restriction in the fuel system...
dguess
can I put a pressure gauge on at the carb and run it and be able to tell if it is th efuel pump? what should the fuel pressure be at idle and under a load?
thanks
Ayuh,... After reading your Other thread, Which should be part of This thread,...
Multipule threads on the Same subject only create Confusion,....
Please don't do this...
Your exhaust is Plugged/ Restricted...
dguess
please see other thread to keep the confusion down. sorry for the inconvienance "Need Help" posted on the same day.
