Ignition coil specs.
7mm
I just purchased a Sierra ignition coil for a 1986, 2.5L, OMC. It tested 5 resistance ohms right out of the box. Is it defective or something special for that model???
Howard Sterndrive
if you're doing the test correctly, defective
what does your meter read for ohms when you touch the 2 leads together?
why do you think its the coil? coils rarely if ever go bad
if your motor isnt running, did you service the points?
gm280
Not uncommon for the primary side of coils to read low resistances. If you understand how a coil works, there are very few windings on the primary side of ignition coils and many many winding on the secondary side to output thousands of volts to jump the spark plug gap. JMHO
7mm
The dealer where I purchased the coil agreed that the coil was defective. He took another off of the shelf and it tested 1.5 ohms. In spec. The old coil in the boat was out of a truck and tested way out of specs.
