Ignition System swap newer 70hp to older 75hp
jeff_32
Is it possible to swap ignition System...stator, timer, power pack...from newer '91 70hp to older '78 75hp and run?
Yes it might work.------But do tell what your motor is doing / not doing ?-----Why do you feel that the entire ignition needs to be replaced?----What trouble shooting / testing have you done?
jeff_32
It's an old timers boat. He had a used power pack installed, didn't last long. He had a new power pack put on by the same shop and same outcome.
I did an ohms test on the stator and timer, both test bad. Timer shorted to ground.
